Please dont give up on me yet
Iam doing my experiment. I got a scap piece of MDF and sanded it ALOT. The cut sidesi gave a REAL good sand too try to seal it as much as possible. So the stain can't soak in to Much.
I then gave it a rub down with some turps with a rag. To get rid of the dust and ****. Recomended by the can
The i did a coat of stain. Colour new Baltic pine. I used a brush, though i have a roller and will try that on my next experiment to see if it makes any difference. I would hope it makes agrain look.Atleast somthing like it.
The sample i have now looks ok. I gave it a nice good sand and it lightened the colour a fair bit. I was alittile concorned that it was to dark. But it looks ok. Iam just leaving it now to see if it fades any. maybe i will need to do another coat before i seal it.
I was told to do a coat of diluted PVA glue before iput the stain on. is this realy nessary. And if so what does it do ???
Thanks for all your help you wonderfull helpfull people :P
Another Nice warm Day In Australia. Damn this country !!!!
Thanks again.
