Im probably no more than 2 weeks away from wall mounting my 42PV500 and to be honest im not looking forward to it one bit.
I have a Vogel's EFW2001
http://www.vogels.com/detail.asp?ISS...=31&ChildID=80
It looks like this:
Now when I read through these forums and look at all of the home installation pictures everyone seems to have used a different looking mount to the one I have.
If you would take this for example:
you will notice that it secures to the wall and the screen at the four corners(as does every other one I see here). The Vogel's mount I have, secures the mount to the wall via three screws positioned in the centre, one lower and two higher (as shown).
Now this makes me worry that this design is not favoured because of the load that is put on that one small central area of the Vogel's mount? Am I right in thinking that the second wall mount would distribute the weight more efficiently due to the space between each fixing?
Has anyone any Vogel's EFW2001 experience or a greater knowledge of general physics where they can put my mind at ease or advise me to immediately buy a new model.
Yours paranoidly,
Liam
