Hi guys.
Looking for a little help with positioning my speakers. I'm currently refurbing a house and I want to run conduit for the cables as its all being replastered. They will be run behind the skirting and then up to their final positions.
The screen (plasma/lcd) will be mounted on a chimney breast with centre speaker either above or below. I am planning on having floor standers in each alcove either side of the chinmey. For the rears I have two options A and B in attached picture. For both positions we will have to mount fairly high - around 2.5m, to get them above the picture rail and doorway height.
Firstly, do I go for position A or B and if so should I mount them so that they are pointing downward. Secondly should the centre speaker go above or below the screen which is above a fireplace (gas living flame type).
I'm looking for teh best position but as I don't have the equipment yet (or any power in the house!) I can't really experiment. BTW I am planning on getting the Tannoy SENYS system for the speakers
Any help or advice appreciated!
Richard
