Recent TH37PV500 Install....pretty basic
Old 06-04-2006, 9:08 AM   #1
3,697, Level: 14
Points: 3,697, Level: 14 Points: 3,697, Level: 14 Points: 3,697, Level: 14
Thanks: Gave 3, Got 8
Phase 1 - Preapring the Chimney Breast
1. Old 28" JVC and fireplace removed. Poor quality due to camera phone.
2. Removal of Fire place brick revealed quite weak structure so a new front and rear lintel were added for strength.
3. Sky+ wires plumbed in new location and new mains loop added under the floorboards.
4. Front Lintel added.
5. My mate bricking the remaining space from the fireplace up. Top chap - very handy.
Phase 2 - Building the MDF Box to house components and prepping central wiring hole
6.
7.
8.
9.
10.
11.
Old 06-04-2006, 9:34 AM   #2
mason's Avatar
5,390, Level: 17
Points: 5,390, Level: 17 Points: 5,390, Level: 17 Points: 5,390, Level: 17
Thanks: Gave 62, Got 85
I will look forward to the progression of this.
I was going to do the same when I had my flat- but I was always a bit scared incase the thing fell in. It was an old victorian style flat so it had been there long enough.
I bet the dust just now is terrible!
G
Old 06-04-2006, 11:18 AM   #3
3,697, Level: 14
Phase 3 - Flooring, wiring, chased speaker wires new skirtings
Phase 4 - Final fitting of the bracket and then the TV
Old 06-04-2006, 11:34 AM   #4
spuddy01's Avatar
3,204, Level: 13
Points: 3,204, Level: 13 Points: 3,204, Level: 13 Points: 3,204, Level: 13
Thanks: Gave 38, Got 22
Talking
WOW thats a pretty nice job you've done there
Old 06-04-2006, 11:39 AM   #5
3,697, Level: 14
Thanks very much. It need a bit of tiding, but overall it does exactly what I wanted it to do - which was free up some space in the front room.
Nick
Old 06-04-2006, 12:30 PM   #6
mountfords
Posts: n/a
Excellent job mate - bet you're chuffed?
Old 06-04-2006, 12:35 PM   #7
Johnny Thunder's Avatar
6,114, Level: 18
Points: 6,114, Level: 18 Points: 6,114, Level: 18 Points: 6,114, Level: 18
Thanks: Gave 238, Got 149
I did the same thing mate. Free's up lots of space putting the kit in the
fireplace. Top job.
Old 06-04-2006, 12:38 PM   #8
GasDad's Avatar
4,993, Level: 16
Points: 4,993, Level: 16 Points: 4,993, Level: 16 Points: 4,993, Level: 16
Thanks: Gave 1,509, Got 722
Thats fantastic - and an option I'm considering doing.
What about ventilation to the chimney stack?
James
Old 06-04-2006, 12:50 PM   #9
6,114, Level: 18
I left the stack open, but fitted a cowl on top to stop water falling in.
Natural cooling for the equipment.
Old 06-04-2006, 1:10 PM   #10
Conspicuous Member
shahedz's Avatar
13,128, Level: 27
Points: 13,128, Level: 27 Points: 13,128, Level: 27 Points: 13,128, Level: 27
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 1,382, Got 724
real nice install you done there mate, and great photos from beginning to end, just got me wondering though , do you have a centre speaker?
Old 06-04-2006, 1:55 PM   #11
ash ash is offline
ash's Avatar
39,712, Level: 48
Points: 39,712, Level: 48 Points: 39,712, Level: 48 Points: 39,712, Level: 48
Thanks: Gave 670, Got 431
All that hard work is great, as you spent that much you could have gone for 42PV500
Old 06-04-2006, 4:11 PM   #12
3,697, Level: 14
Kind comments guys....
Ventalation - there is an inch gap between the bottom of the drain pipe and the top of the MDF cabinet - this has some gauze around it to stop dust but allow air. Works a treat. Amps a bit tight, but there is about 2" inside the lip of the shelf so not too bad.
Centre Speaker - Yip, the two wire sticking out above the TV on the very last shot now go into a Tannoy EFX centre. Not wonderful kit but good enough for now. New Picture attached to show centre channel...
TH42PV500 - I'm more than happy with the 37" - it's not a very big room. Most of the viewing seats are a maxmimum of 8 feet away - I think 37" is just right for the room size. Besides the 37" was £1685 and the 42" was £1999. Quite a difference.
pete s (08-12-2008)
Old 06-04-2006, 5:57 PM   #13
7,243, Level: 20
Points: 7,243, Level: 20 Points: 7,243, Level: 20 Points: 7,243, Level: 20
Thanks: Gave 4, Got 36
Very nice NB , well done for taking the pics , top job
Jon
Old 06-04-2006, 6:46 PM   #14
3,696, Level: 14
Points: 3,696, Level: 14 Points: 3,696, Level: 14 Points: 3,696, Level: 14
Thanks: Gave 41, Got 21
Top job... nice photos.
Looks plane and simple no messy wires (bet the missus is happy!) mine is.
Old 06-04-2006, 7:21 PM   #15
scharf_10's Avatar
5,490, Level: 17
Points: 5,490, Level: 17 Points: 5,490, Level: 17 Points: 5,490, Level: 17
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 250, Got 90
Thats really good, which i had shown some installation pictures on my bedroom. Being 16 i dont have control over what happens in the livingroom, but this makes me want to try and persuade the parents to do it
Old 06-04-2006, 9:27 PM   #16
Jeffers01's Avatar
4,544, Level: 15
Points: 4,544, Level: 15 Points: 4,544, Level: 15 Points: 4,544, Level: 15
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 53, Got 35
Nice job
Old 08-04-2006, 7:24 AM   #17
mason's Avatar
5,390, Level: 17
top quality finish
Old 10-04-2006, 12:06 PM   #18
Daipac's Avatar
10,925, Level: 25
Points: 10,925, Level: 25 Points: 10,925, Level: 25 Points: 10,925, Level: 25
Thanks: Gave 46, Got 12
I gotta say, that is superb ! TOP TOP JOB and how I want mine to look when I finally get around to doing it !
What was in the chimney breast beforehand ? Did you have a fire ?
Old 10-04-2006, 12:46 PM   #19
Kenny Glasgow's Avatar
12,077, Level: 26
Points: 12,077, Level: 26 Points: 12,077, Level: 26 Points: 12,077, Level: 26
Thanks: Gave 71, Got 228
Very nice job
Old 10-04-2006, 4:09 PM   #20
3,697, Level: 14
DAIPAC - I did have a fireplace in there, ripped the whole lot out, got rid of everything and capped off the gas and stuck it below the floor boards as we never used the fire because the radiators are tip top in that room.
Thanks again guys for the comments.
