Here's my little home cinema project that I have undertaken recently after we moved house. Loved the house when we first found it, but I couldn't see an easy solution for where to mount my plasma and speakers.
This was how it all used to look in my old place...
And this was how the living room looked before we moved in...
After day one of the building work...
I got the builders to stick a 50mm bit of trunking in on the right hand side of the stud wall for all the cables. They also put me in some extra noggins where the left hand speaker needs to go.
After day two of the building work...
I got the builders to put the left hand speaker cable in for me, plus they drilled me a hole into the trunking for the centre speaker. That just left me the right hand speaker to do.
Getting everything measured up...
I just had to chase a short bit of wall for the right hand speaker and ran conduit through to the hall cupboard to join up with all the other cables coming along through the new skirting.
Just papered the wall, nearly ready for painting. The bit above the door won't dry though! Had to wait days for that.
And the finished product...
