I was wondering if anyone can help.
From the picture you'll see I'm making my old double garage into a av room.
The back wall has been blocked up and now I'm having a stud/false wall of around 26cm from the back made. In the centre I'm leaving a void for the mounting of a 50" plasma.
This will be mounied on a stud partition with a clearance between the main brick back wall and the front. This will be used to mount the plasma, the 5cm gap will so that i can bring cables through to behind the plasma.
My problem is that as it was a garage, I have to leave me main electrics/gas stuff in the corner as you can see. So i'm having a tall mdf cupboard made, on the side which then angles at 45deg to the false wall being created. within the angled section of the cupboard, I'm going to hosue my cat5/video distribution and av kit.
My inital questions are ;
1. If I use thick MDF screwed to 2"x2" battens which are then screwed/fixed to the rear wall, is this strong enough for a CHIEF universal flat mount and a Philips PF7230 50". I think the plasma weighs 70KG.
2. I intend to stick allthe av kit - amp/dvd/sky etc behind an mdf door.
Is this possible with regard to remote control operation.
The aim was to have a clean white wall with "rectangle hole" for the plasma and nothing visible.
Has anyone done anything similar... Any help/pointers would be greatful.
Dave.
