Vogels VFW 140 and Toshiba 32"
Old 04-03-2006, 9:32 PM   #1
2,686, Level: 12
Points: 2,686, Level: 12 Points: 2,686, Level: 12 Points: 2,686, Level: 12
Thanks: Gave 4, Got 1
I have just mounted my Tosh with a Vogels VFW 140 tilting mount (as recommended by Toshiba) but I can see the mount above the screen.
Is this normal? Am I going to have to cover the mount or paint it?
I have tried various holes on the mount and I have it connected to the TV on the lowest option but I can still see a good 2" of mount.
I can post a pic if I am not making myself clear.
Old 05-03-2006, 7:36 AM   #2
4,518, Level: 15
Points: 4,518, Level: 15 Points: 4,518, Level: 15 Points: 4,518, Level: 15
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 10, Got 14
I bought a VESA compliant wall bracket, small, neat and sits the tv very close to the wall and cannot be seen from any angle....
Plus, as a bonus, only £19.99 from Tescos.
Must be a large bracket that you've got?
Mine is small (about half A4 paper size) and is currently happily supporting a 42" Toshiba on the wall.
Are there any options to move the position of the actual brackets on the back of the tv, i.e. adjust them up or down?
Old 05-03-2006, 9:47 AM   #3
2,686, Level: 12
The bracket is quite large but its what Toshiba said to buy.
There are lots of options for movement but I have it on the lowest. Has anyone else installed the same combination?
I think I will make a very thin box and box it in.
