28" LCD TV on a shelf - will it hold!?
Old 22-02-2006, 9:25 AM   #1
Wunkley
Posts: n/a
Rather than buying a wall mount bracket thing, I was toying with the idea of having my Hitachi 28" LCD just on a shelf above my computer desk, to complete the superscreen set up (will be 3 screens then - sad but true)
Details are:
TV weighs 18.5kg
Shelf brackets are 'rated' to hold up to 25kg
The wall is your normal modern house internal plasterboard affair - ie doesn't feel too strong, which is what is worrying me.
Thoughts?
Old 22-02-2006, 9:49 AM   #2
4,160, Level: 15
Points: 4,160, Level: 15 Points: 4,160, Level: 15 Points: 4,160, Level: 15
Unless you can screw into the studs in your internal wall I wouldn't risk it! I think studs are usually 400mm or 600mm apart but you would have to check by knocking on your walls, try a few discreet drill holes (small ones!) to establish where they are if you cant find out...good luck
Old 22-02-2006, 12:58 PM   #3
Wunkley
Posts: n/a
Don't think i will risk it - is a new house and don't want any accidents and don't want to be drilling holes if I can help it (Mrs 'Wunkley' would disembowel me for a start).
I've a big desk so will have all 3 on that and just slide my smaller lcd out of the way as and when needed I think...
