remote control curtain closers???
Old 21-01-2002, 11:07 PM   #1
7,764, Level: 21
Points: 7,764, Level: 21 Points: 7,764, Level: 21 Points: 7,764, Level: 21
Thanks: Gave 10, Got 2
Arrow remote control curtain closers???
where can i buy a remote control curtain closers?B and Q dont sell them anymore????????any ideas??did a search and found a company in uk ,but they where £350 for motor and track!does swish the company which B AND Q used to get them off still do them?many thanks gg
Old 22-01-2002, 8:02 PM   #2
Thor's Avatar
4,764, Level: 16
Points: 4,764, Level: 16 Points: 4,764, Level: 16 Points: 4,764, Level: 16
Thanks: Gave 2, Got 2
Hi grahamricho.
This is just a suggestion, but have you heard of X10 Home Automation . You can use remote controls or your computer to operate these devices. X10 sends its information through the mains wiring of your house at high frequencies to devices that can be bought off the shelf. This means that there is no messy wiring required and these systems can be set up in minutes.
You are after 'a remote control curtain closer', so I think this may be your answer. Look at this site and decide.
http://www.cyberselect.co.uk/HomeAut...ainMotors.html
Old 30-01-2002, 1:11 AM   #3
5,250, Level: 17
Points: 5,250, Level: 17 Points: 5,250, Level: 17 Points: 5,250, Level: 17
Thanks: Gave 3, Got 3
Check out the www.letsautomate.com site. That's where I got my 'Swish' devices and so far (touch wood) they've worked fine - been going 18 months so far.
Old 30-01-2002, 9:47 PM   #4
leon's Avatar
8,656, Level: 22
Points: 8,656, Level: 22 Points: 8,656, Level: 22 Points: 8,656, Level: 22
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 16, Got 56
hiya
i bought mine form here a couple of month ago ,he has bought up all the motors from bq (country wide )
swish have been taken over by a new company but i heard they have plans to re-introduce the electric curtains again.
http://www.ronin100.pwp.blueyonder.c...%20cinema.html
Old 14-02-2002, 4:38 PM   #5
jrwood
Posts: n/a
Anyone know how much it costs to have this going through the mains?, are we talking about 10p a month?! or more? / less?
Thanks!
James
Old 14-02-2002, 7:26 PM   #6
Thor's Avatar
4,764, Level: 16
If your talking about X10, then virtually nothing, signals are only sent to turn the device on/off, the rest of the time nothing is being sent.
