Electric curtains!
Old 13-11-2001, 2:59 PM   #1
JDC
Posts: n/a
Electric curtains!
Has any one got them, or know where I can get either a ready-to-use set or the components for them?
I'm sure I could cobble together a system using standard corded track & a geared motor with IR control mounted on a baseplate on the wall - but life is sometimes easier if someone else has dome all the engineering...
Old 13-11-2001, 3:02 PM   #2
Founder
Stuart Wright's Avatar
146,883, Level: 92
Points: 146,883, Level: 92 Points: 146,883, Level: 92 Points: 146,883, Level: 92
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 902, Got 4,625
See the little 'search' button up near the top of the screen?
Click it, type 'electric curtains' in the box and hit 'Perform Search'.
Old 13-11-2001, 3:08 PM   #3
JDC
Posts: n/a
Ah... that'll that'll be the one.
Thx!
Old 14-11-2001, 5:50 PM   #4
Thor's Avatar
4,764, Level: 16
Points: 4,764, Level: 16 Points: 4,764, Level: 16 Points: 4,764, Level: 16
Thanks: Gave 2, Got 2
I've seen an electric curtain system that you can buy off the shelf, which you should be able to buy locally, that is if you have a B&Q store near you. It has remote too. Ask at your local store.
