Remote Control Switch info needed?
Old 14-10-2005, 3:44 PM   #1
6,013, Level: 18
Points: 6,013, Level: 18 Points: 6,013, Level: 18 Points: 6,013, Level: 18
I need a remote control switch for an appliance. There are lots available that are operated by RF or X10 but those are not an option for me. I need one to use with my Pronto Remote Control so it has to be infra red, preferably with discreet on and off codes and NO dimming.
Does anyone know of such a product? I've checked various sites and can't seem to find anything.
Cheers,
Gareth.
Old 14-10-2005, 6:14 PM   #2
Docta teef's Avatar
7,379, Level: 20
Points: 7,379, Level: 20 Points: 7,379, Level: 20 Points: 7,379, Level: 20
Thanks: Gave 42, Got 40
You can buy an rf/ir convertor for x10 that would let you use the pronto
Old 18-10-2005, 10:19 AM   #3
6,013, Level: 18
Thanks. I have now decided to go down the X10 route to solve my problem. I don't want dimming as I just want a simple on/off switch at present. Although now I've got X10 I guess that'll open up and lot of new areas for control
