Soundproofing a Door.
Old 11-10-2005, 12:55 PM   #1
Les E's Avatar
8,721, Level: 22
Points: 8,721, Level: 22 Points: 8,721, Level: 22 Points: 8,721, Level: 22
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 13, Got 19
I think my weakest spot in my home cinema for sound leakage will be the door in & out of the room.
However I don't want the look of a heavy fire door and would like to keep the white internal doors we have around the house presently.
So if I used one of the white doors and backed it with Rockwool and screwed a piece of thick MDF to the back of it (which will be the side in the HC) and filled the edging with MDF strips, would this be adequate to soundproof the door?
Any thoughts would be welcome!
Old 11-10-2005, 1:24 PM   #2
12,947, Level: 27
Points: 12,947, Level: 27 Points: 12,947, Level: 27 Points: 12,947, Level: 27
Thanks: Gave 110, Got 108
it will reduce the transmission a small amount, but it wont soundproof it totally, you would have to have the door 'seal' when it shuts to do it properly, have a look at this link:
http://soundproofing.org/infopages/s...fing_doors.htm
Old 11-10-2005, 2:26 PM   #3
Les E's Avatar
8,721, Level: 22
Activity: 2.3%
I suppose if I coated it with a soundproof panel/foam wouldn't really do the trick either?
Old 11-10-2005, 2:55 PM   #4
12,947, Level: 27
if you put fiberglass panels or foam panels it would reduce the noise a little but not much, you would have to use MLV over the door to really make a difference, but then you would still get bleed round the door.
Old 11-10-2005, 5:35 PM   #5
4,018, Level: 14
Points: 4,018, Level: 14 Points: 4,018, Level: 14 Points: 4,018, Level: 14
Thanks: Gave 9, Got 8
really interested in doing this aswell, does anyone have an approx price and location to buy for a self installed seal to be added to a standard door?
Old 12-10-2005, 9:43 PM   #6
4,018, Level: 14
anyone?
Old 18-10-2005, 11:03 PM   #7
4,018, Level: 14
again anyone?
Old 19-10-2005, 9:17 AM   #8
12,947, Level: 27
i dont, sorry. though saying that perhaps the squashy rubber that you can buy for veitlation soundproofing purposes might do the trick for door frames?
Old 19-10-2005, 12:09 PM   #9
Jamiroquai78
Posts: n/a
This covers most requirements I think.
http://www.customaudiodesigns.co.uk/seals.htm
Jam
