Hiding light switches
Old 05-10-2005, 1:20 PM   #1
DigiTALGuy
Posts: n/a
My plan for a home cinema seems to be working, I've decided to paint a screen using matt white onto the wall instead of forking out for a screen - the only problem is that there's a light switch in the way and i'd have to project over it.
Are there any clever solutions to disguise it?
Old 05-10-2005, 2:29 PM   #2
Conspicuous Member
shahedz's Avatar
13,120, Level: 27
Points: 13,120, Level: 27 Points: 13,120, Level: 27 Points: 13,120, Level: 27
Thanks: Gave 1,382, Got 722
i dont think you can, because the switch will stick out of the wall, and you will be able to see it when you project an image
Old 05-10-2005, 8:35 PM   #3
inzaman's Avatar
22,356, Level: 36
Points: 22,356, Level: 36 Points: 22,356, Level: 36 Points: 22,356, Level: 36
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 126, Got 543
I'd agree with the above, if you want a cheap screen how about the DIY route, you could even paint a sheet of mdf and put that onto the wall.
You could change the light switch to a remote control one, not sure if this would work through mdf or fabric though, does anybody else know?
Old 07-10-2005, 5:49 PM   #4
stoner
Posts: n/a
you could move the switch, if its upstairs in a house then its easy.
also forber and lomax do a clear glass switch, but you'd still see the actual switch , just the place is see through. Moviing the switch is the best option IMO
Old 09-10-2005, 4:19 PM   #5
4,888, Level: 16
Points: 4,888, Level: 16 Points: 4,888, Level: 16 Points: 4,888, Level: 16
If the switch was for the room that you are in, you could find a way of getting a remote control light switch system from somewhere and just take that switch and stick it into the way and plaster over it to make the wall smooth, then you'd have a remote control to control the lights! I'd prefer to do that even! (as long as the remote control is radio frequency and NOT IR)
Ryan
Old 10-10-2005, 9:41 PM   #6
5,947, Level: 18
Points: 5,947, Level: 18 Points: 5,947, Level: 18 Points: 5,947, Level: 18
This would be ideal, but it doesn't look like it is available in exactly this form any more.
Might be possible to do something with a sensor switch module?
