Speaker grill cloth
Old 24-10-2001, 6:01 PM   #1
Timh's Avatar
22,944, Level: 36
Points: 22,944, Level: 36 Points: 22,944, Level: 36 Points: 22,944, Level: 36
Activity: 7.4%
Activity: 7.4% Activity: 7.4% Activity: 7.4%
Thanks: Gave 183, Got 82
Question Speaker grill cloth
Does anyone know where to buy speaker grill cloth from, Tandy use to sell it some time back.
Old 24-10-2001, 6:21 PM   #2
5,922, Level: 18
Points: 5,922, Level: 18 Points: 5,922, Level: 18 Points: 5,922, Level: 18
Post
Tim
Maplins sell it, (they used to anyway, I bought some from there!). Nearest I know of are Manchester or Stockport or check their website.
Cheers!
Old 24-10-2001, 7:02 PM   #3
Timh's Avatar
22,944, Level: 36
Activity: 7.4%
Post
Cheers Dave, I will take a look at their website.
Old 24-10-2001, 9:06 PM   #4
Bone Daddy's Avatar
5,862, Level: 18
Points: 5,862, Level: 18 Points: 5,862, Level: 18 Points: 5,862, Level: 18
Thanks: Gave 0, Got 2
Cool
If you have no luck there Timh,try your local car audio installer,a friend did a real nice job on his converted garage with grille cloth-you can buy it by the metre,very handy :D
Old 25-10-2001, 6:22 AM   #5
Timh's Avatar
22,944, Level: 36
Activity: 7.4%
Smile
Thanks Bone, I will keep that in mind.
Old 26-10-2001, 2:20 PM   #6
7,884, Level: 21
Points: 7,884, Level: 21 Points: 7,884, Level: 21 Points: 7,884, Level: 21
Thanks: Gave 15, Got 36
If you still have no luck try http://www.iplacoustics.co.uk , they sell a lot of DIY stuff i.e. grille material, veneer etc.
Old 28-10-2001, 12:27 PM   #7
17,635, Level: 32
Points: 17,635, Level: 32 Points: 17,635, Level: 32 Points: 17,635, Level: 32
Activity: 17.0%
Activity: 17.0% Activity: 17.0% Activity: 17.0%
Thanks: Gave 191, Got 215
Thumbs up
Failing all that , try Wilmslow Audio , i,ve had it from there in the past.
Kev
