have a look at this
Old 16-09-2005, 1:01 PM   #1
2,282, Level: 11
Points: 2,282, Level: 11 Points: 2,282, Level: 11 Points: 2,282, Level: 11
Thanks: Gave 6, Got 3
have a look at this
Tom: hi
leigh : hi i want to soundproof my walls what are the best things to use im in to homecinema and i have heard bad things about resilient channel
Tom: Your best option would be our Resilient Bar System. This will take up a maximum of 5.5 inches and will reduce everyday noise and music by approx 70 %. I have pushed a page at you to view for more info on this system. If it does not open then please click on the link. I would look at the flash animation on this page first to get and idea of products and the layout.
Tom: http://www.customaudiodesigns.co.uk/...howtowalls.htm
Tom: You should not have heard any bad things about it
Tom: If you have it will be from someone who has not installed it properly
Tom: or another soundproofing company who are trying to push you there system
leigh : they say it sucks all the bass out of the room
Tom: It does not absorb the bass
Tom: it just stops it from leaving
leigh : ok thanks for the link
Tom: Is there anything else I can help you with ?
leigh : no im fine thanks
Old 01-10-2005, 10:09 AM   #2
Founder
Stuart Wright's Avatar
146,777, Level: 92
Points: 146,777, Level: 92 Points: 146,777, Level: 92 Points: 146,777, Level: 92
Activity: 20.5%
Activity: 20.5% Activity: 20.5% Activity: 20.5%
Thanks: Gave 901, Got 4,623
Sorry but what's the point of this post? Sounds like an advert to me.
Old 01-10-2005, 10:49 AM   #3
2,282, Level: 11
have a look at this
its not an advert its people keep saying that resilient channel is rubbish and this is the conversation i had with the chap at custom audio design
Old 01-10-2005, 1:01 PM   #4
12,947, Level: 27
Points: 12,947, Level: 27 Points: 12,947, Level: 27 Points: 12,947, Level: 27
Thanks: Gave 110, Got 108
Custom Audio dont make or install RC, they just sell it
if RC is installed incorrectly it wont work properly. Bass will get 'sucked' out of a room if the edges are not sealed or if the board resonates at the same frequency, say 40hz, it is possible to 'short circuit' RC, this reduces its effectiveness.
