Which leads fo my home cinema?
Old 15-08-2005, 10:39 AM   #1
6,583, Level: 19
Points: 6,583, Level: 19 Points: 6,583, Level: 19 Points: 6,583, Level: 19
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 516, Got 76
Hi all, i have just set up my home cinema, got the universal mount bracket from a guy in the USA, which was only £25 delivered and is fantastic, the original Sanyo one is around £160 last time i looked!
Any way, i just wanted to know what leads will give me the best picture:
1) - Is an S Video lead better or worse then a scart lead?
2) - I have 3 RGB connectors on the back of the projector are these to be used from a scart lead and then use an adaptor to the three leads?
I will try and get pics up when i get the chance!
Old 15-08-2005, 2:01 PM   #2
Kenny Glasgow's Avatar
12,077, Level: 26
Points: 12,077, Level: 26 Points: 12,077, Level: 26 Points: 12,077, Level: 26
Thanks: Gave 71, Got 228
Deefadog
What will be feeding the PJ? If your DVD player (or processor or scaler) has Component then that will be better than SCART or S-Vid
Get yourself a good set of Component cables from Mark Grant in the Cable Section Power Buys
Old 16-08-2005, 7:25 AM   #3
6,583, Level: 19
Activity: 1.5%
Hi, thanks,
I will have a look if it has component connectiones, can these be RCA or
BNC connectors? red, blue and green?
Old 16-08-2005, 7:54 AM   #4
12,077, Level: 26
deefadog
They can be either. Mark Grant can make the cables with different terminations at each end. Just tell him what you require and you'll get a set that are as good (if not better) than cables costing several times the price
Old 17-08-2005, 7:54 AM   #5
6,583, Level: 19
Activity: 1.5%
Thanks kenny, i'll contact Mark nearer the time. I will be moving soon and want to get all the fact down, so when i start channeling walls i can put in the right leads!
I had a good look at the projector and it has these connections:
S Video connection
Componet connectors
DVi-i
So in order which is the better connection starting from best to worst?
Old 17-08-2005, 8:05 AM   #6
12,077, Level: 26
Well in theory it should be
DV-I
Component
S-Vid
If your DVD player had DV-I then I'd probably go for that. Remember that Sky are launcing their HD service next year and if you have other equipment you want to connect like and X-Box or PS or PC then you might want to think about getting an external scaler like a Lumagen or iScan. Then things get really interesting
Gordon from Convergent can advise
Old 17-08-2005, 8:36 AM   #7
6,583, Level: 19
Activity: 1.5%
Thanks kenny, i have two more questions, if you don't mind:
Is scart better than s-video?
and what effects will i have if i use a scart one end and the component adapter on the other end of the scart?
Old 17-08-2005, 9:07 AM   #8
12,077, Level: 26
Deefadog
I personally don't like SCART but it's hard to avoid them! If you can I'd go for a straight Component to Component as it should give you the best quality picture.
Why do you need the SCART --> Component?
Old 17-08-2005, 9:48 AM   #9
6,583, Level: 19
Activity: 1.5%
I maybe getting confused, but i don't have component outputs on my DVD player but i do have scart, i thought i could use the scart adapter to get coponents out put? or are is this adaptor for video and sound?
But S-video is better than scart though yes?
Old 17-08-2005, 10:01 AM   #10
12,077, Level: 26
I'm sure it can be done although the cables maybe a bit thick for the SCART plug.
Why don't you post in the Component section of the Cables Power Buys and ask Mark direct
Old 17-08-2005, 10:45 AM   #11
6,583, Level: 19
Activity: 1.5%
Thanks I will ask him!
So is S-video is better than scart connection?
Old 17-08-2005, 11:00 AM   #12
12,077, Level: 26
In theory a SCART wired for RGB should be better than S-Vid
Old 17-08-2005, 11:09 AM   #13
6,583, Level: 19
Activity: 1.5%
I see, so ther are different types of scrat leads, this does get confusing. i am guessing there is an RGB Scart and a standard scart lead?
Sorry for all the questions
Old 17-08-2005, 11:25 AM   #14
12,077, Level: 26
and you can also get SCARTS wire for both picture and sound or only picture......
It's all to do with the 21 pins
Old 17-08-2005, 11:28 AM   #15
6,583, Level: 19
Activity: 1.5%
