Advice required : diy a good simple phono switchbox
Old 30-07-2005, 3:39 PM   #1
Conspicuous Member
20,517, Level: 34
Points: 20,517, Level: 34 Points: 20,517, Level: 34 Points: 20,517, Level: 34
Activity: 9.8%
Activity: 9.8% Activity: 9.8% Activity: 9.8%
Thanks: Gave 86, Got 383
I need a good 2 into 1 phono switchbox to feed my headphone amp at work either my PC output or my CD player as I'm getting fed up with yanking cables.
I assume this is a piece of cake to build but I want to ensure I use the best possible components. ( hence my reasons for avoiding some 5quid plastic box)
Now I know very little about electrical components so could someone advise me on the best switch type to use ( it has to be passive so really can't be a relay) to ensure no nasty noise or ground problems?
Basically I need a shopping list : phono sockets and project cases are readily available from maplins/farnell but I really need some advice on the switch itself and any other issues that you think might be relevant.
I know beekeeper had a diy component switchbox that used a relay but like I said I want a nice simple passive switchbox that has minimal effect on the sound quality.
cheers
Old 30-07-2005, 4:27 PM   #2
Conspicuous Member
20,517, Level: 34
Activity: 9.8%
Actually I just found this one on headwize.
http://headwize.com/projects/showfil...=cmoy7_prj.htm
Its ugly as sin , has headphone jacks instead of phonos and two outputs but I guess its a good place to start.
Old 30-07-2005, 4:42 PM   #3
Conspicuous Member
20,517, Level: 34
Activity: 9.8%
Actually with the two outputs I could build in a crossfeed circuit and gain the ability to switch the crossfeed in and out of the circuit ...I think.
Old 01-08-2005, 1:24 PM   #4
4,906, Level: 16
Points: 4,906, Level: 16 Points: 4,906, Level: 16 Points: 4,906, Level: 16
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 12, Got 46
These are the type of switches to use (get the gold plated version)
http://www.farnell.com/datasheets/32143.pdf
Old 04-08-2005, 9:36 PM   #5
Conspicuous Member
20,517, Level: 34
Activity: 9.8%
Many thanks.
