Audio Video Cables & Quick Drying Cement?
Old 07-03-2005, 6:52 PM   #1
WBC WBC is offline
8,304, Level: 21
Points: 8,304, Level: 21 Points: 8,304, Level: 21 Points: 8,304, Level: 21
Thanks: Gave 9, Got 2
Guys,
I've chased out my concrete floor for cables to my speakers and TV. It's not deep enough to trunk but can I still fill it back in with quick drying cement???
I'm under the impression that it won't damage the cables, Is that true??
Stace
Old 07-03-2005, 6:58 PM   #2
Johnny Thunder's Avatar
6,114, Level: 18
Points: 6,114, Level: 18 Points: 6,114, Level: 18 Points: 6,114, Level: 18
Thanks: Gave 238, Got 149
Is the chase deep enough to put capping over the cables....?????
Old 08-03-2005, 10:28 AM   #3
WBC WBC is offline
8,304, Level: 21
Its not a very tidy chase and I dont think its deep enough for both capping and cement???
Will the cement damage the cabling?
Stace
Old 08-03-2005, 12:27 PM   #4
hatcher
Posts: n/a
Possibly. I have heard that the active ingredient in some cements/fillers/plasters can attack the pvc sheath around cables. I'd check with the manufacturer of whatever your planning on using. From personal experience I have buiried a coax (for a tv) with polyfiller and that's been okay, but other than that I have always used conduits.
Perhaps you could wrap it something first?
Cheers,
Hatch
Old 08-03-2005, 9:45 PM   #5
3,723, Level: 14
Points: 3,723, Level: 14 Points: 3,723, Level: 14 Points: 3,723, Level: 14
Thanks: Gave 4, Got 1
I know that when Copper Gas pipes are concreteed into floors. The Copper pipes that are used have a Yellow pvc protecter on them to stop Cement arrosion of the Copper pipe.
So with this in mined I would have thought that it would be alright.
I would chase out a deeper duct and put proper ducting in just for Future proofing
