seal for cable entry point
Old 13-02-2005, 11:22 AM   #1
abs abs is offline
6,933, Level: 19
Points: 6,933, Level: 19 Points: 6,933, Level: 19 Points: 6,933, Level: 19
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 127, Got 74
does anyone know if a rubber seal or similar is available to seal a hole in a brick wall from where my cables enter the room, ie a seal to allow cables in but to stop anything else, ie insects, weather etc...
Old 13-02-2005, 11:43 AM   #2
9,762, Level: 23
Points: 9,762, Level: 23 Points: 9,762, Level: 23 Points: 9,762, Level: 23
Thanks: Gave 0, Got 2
You could try a closed grommet. I have one destined for the hole drilled in my ceiling where the PJ component cable comes in. The desk grommets below show you what they look like but I'm not sure where you can buy them... I got a couple given to me a while ago.
http://cableorganizer.com/desk-gromm...=googlewords#B
Old 13-02-2005, 12:28 PM   #3
abs abs is offline
6,933, Level: 19
Activity: 2.7%
thanks mate, that is what i'm after, will try B&Q today
