I thought I would start at the beginning of my dedicated Home Cinema Room to be incorporated into the new extension we have planned next year.
The plans have just come in from the architect and we're just waiting for them to go thru the usual channels before the build.
So to start with, I am posting the part of the architects drawing that involves my dedicated room and I will follow with photos of the build and hopefully all the stages involved with my Home Cinema.
This could take a while as the rest of the house needs furnishing/decorating before I can spend some serious dosh on the room.
However all of my existing kit is going in but the Television is being replaced by an Infocus Screenplay 4805/5700 (two minds as yet...budget depending!!) with an Onyx Draper screen. I am planning to fit the DVD player via DVi, Sky+ via S-video and a PS2 via component (thru the amp) all up to the projector. I am also toying with getting a scaler for the Sky footage but that will have to come in time...and I am not too sure whether I would need one?
This is where I could do with a bit of advice.
Looking at the plans and the size of the room (roughly 8ft by 11ft and 7 1/2ft high) could anyone give me a reasonable size of screen for the room and a height for wall mounted speakers in a 6.1 set-up? (Kef eggs to be exact!)
I am getting all the wiring pre-installed prior to plastering with the projector mounted from the ceiling.
I am also thinking of having halogen spots wired to the ceiling (sparky is gonna love me!), possibly a couple of uplighters with a lutron dimmer to control the lights.
Any help or advice at this stage would be greatly appreciated especially on the installation/build.
