| Wall mounting PW6 best connection?
Hello all i have asked this question under other headers but had so many opinions i just want to get the best way then go for it!
What i am looking to do is connect a pw6 wall mounted to a sony dav sa30 and pace sky + box. i have listed the specs for the 2 items below. As i am looking to create a minimalistic look i want to have the sky + and dav sa30 on the opposite wall.. this will involve chasing out the wall below the PW6 then running what ever cable i go for through a 12mm hole in a wall for about 8 meters then back in through another 12mm hole. The reason I am looking to go through the wall is to completley hide the cables cos my chick hates them and this is one of the conditions of being allowed to buy a plasma in the first place as in " think of how much room it will save and no more cables !" oooo rrrr so if you guys can give me one last opinion before i shed out 2k plus cables and converters it would be greatly appriciated.. getting rid of my bird is not an option !
Sony Dav SA-30
Connectors
RGB out
Composite video in, analogue audio in
Composite video in/out, analogue audio in/out
Speakers (5.1 ch)
AM loop/FM
Front
Mini-jack stereo audio out
Power voltage: 240V (European)
Video output
PAL to PAL
NTSC to NTSC
Main features
Integrated 5.1 DVD Hi-Fi System
S-Master Fully Digital Amplifier
DVD, SACD, Dolby Digital, Dolby Pro-Logic 2 & DTS decoding built-in
DVD/SACD/CD/CD-R/CD-RW/VCD Playback
Wide Frequency range speakers for SACD Audio
FM/AM Radio Tuner Built In
SCART Output (RGB & Composite output with TV audio in)
MP3 Playback
JPEG Playback, slide show
300w Total Power Output
Technical specs
Type
5.1ch Dolby digital decoder Yes
DTS decoder built-in Yes
DVD/SACD/CD/CD-R/CD-RW Yes
Video CD player/AV amplifier / FM/AM tuner Yes
Horizontal line resolution Approximately 500 Lines
SACD playback
Playback frequency range 2hz - 100kHz
Audio frequency characteristics 2hz - 44kHz
Audio THD >0.03%
Wow * flutter Below measurement limit (?.001% WPEAK)
DVD/CD playback
Audio frequency characteristic (2ch STEREO mode) DVD (at the time of PCM playback): 2hz - 22kHz (?.0dB) At the time of CD playback: 2hz - 20kHz (?.0dB)
THD >0.03%
Wow * flutter Below measurement limit (?.001% W PEAK)
General
Power Output Total 300W: 5x 44W (Satellites) (6⒛x passive sub woofer 80W (RMS 10%)
Weight Approx. 4.0kg
SKY + (box is previous model but spec is the same)
1. AC Input - From mains power supply
2. Telephone line Connector RJ11
3. UHF Modulator - For connection to main TV and optional
connection to second TV
4. TV A/V SCART - Provides either composite or RGB and
composite video output. Audio volume can also be controlled
in software
5. VCR A/V SCART - VCR Scart for connection to Video Recorder
6. Analogue Audio Outputs - An important addition for users
wishing to integrate the set-top box into their home audio system.
Volume can be adjusted or muted under software control
7. S-Video Connector - For high quality connection to plasma
monitors or VHS Recorders
8. SP-DIF - For connection to home Dolby Digital amplifier
9. RS232 - Serial port connector for service and factory use only
10. RF Input - Twin IF inputs to connect to dual LNB at dish
