ShinObiWAN you make a very good point.
I shudder to think how much that VOLT driver costs and it is clearly many, many classes way above what we are talking about here, like thousands of pounds. (But you did put it on ebay for 99p)
Just for the record, the reason I want to SPL it is to see how flat it's response is, not how loud it can go
But what we are talking about here is whether it is worth upgrading the £27 pound woofer that a lot of us here bought to make a certain home brew sub ie. a REL-alike, and some are now worried about.
I picked this Shark driver up as grey import from the far east for very much less than the price of a Shiva but with up to twice as much on paper performance. And some of them presumably in the wrong direction. So I should probably be missing out on something, be it sound quality, lifespan or whatever.
I am simply experimenting in improving the current crop of REL100 clones for tightness and depth but using the same box and amp, so i've just bought a driver of questionable quality/origins which didn't break the bank to see if I could improve things. So this was meant as a risky experiment.
Dave
Edit: Dare I suggest that I suspect my one shark driver in a REL100 clone box in my 32 foot living room doing the LFE for ATOC might sound a little different than two did in Shinobiwan's brother's car?
In jest,
Dave
