auralex lenrd sizes ?
Old 03-03-2004, 2:56 PM   #1
7,884, Level: 21
Points: 7,884, Level: 21 Points: 7,884, Level: 21 Points: 7,884, Level: 21
Thanks: Gave 15, Got 36
Anyone got any and can tell me the dimensions the normal Lenrd's would seem to be about 12"X12" (is that diagonal width or flat width). But what are DST Lenrd's they seem to be a bit cheaper.
Slingshot
Old 03-03-2004, 3:06 PM   #2
8,447, Level: 21
Points: 8,447, Level: 21 Points: 8,447, Level: 21 Points: 8,447, Level: 21
My regular LENRDs are 12"x12"x24" in size - the 'square' dimensions, no diagonals. The DST LENRDs are the same size, but the cutting is less involved and I think that makes them cheaper to produce.
Old 03-03-2004, 4:36 PM   #3
7,884, Level: 21
Cheers Deckard, i'll have to measure tonight see if I can fit any in.
