Auto Screen Drop
Old 17-02-2004, 4:30 PM   #1
6,103, Level: 18
Points: 6,103, Level: 18 Points: 6,103, Level: 18 Points: 6,103, Level: 18
Thanks: Gave 2, Got 1
Auto Screen Drop
Does anyone know any way to automatically lower an Owl 8ft screen if your projector does not have the "send signal" out type connection.
I understand there is a box of tricks that detect a voltage decrease and can lower but how would this handle a remote macro that fires up the DVD / AMP & Projector etc. etc. (only want to lower on the projector)
Apart from RF, is there anyother way?
Bascially anyway where using a IR remote the screen can automatcially lower?
Any ideas?
Kentlad
Old 17-02-2004, 6:57 PM   #2
ReTrO's Avatar
15,958, Level: 30
Points: 15,958, Level: 30 Points: 15,958, Level: 30 Points: 15,958, Level: 30
Thanks: Gave 14, Got 51
So what you need is an interface to make the csreen lower on any IR command?
I know a product that will do the job, it just depends what budget you have in mind.
Take a peek here: (PDF data sheet etc)
Marata MCU-300-4
Not sure of a retail on them as they're mostly used on CI jobs.
Regards
Richard
Tech Support @ Marata Vision
Old 17-02-2004, 11:29 PM   #3
4,263, Level: 15
Points: 4,263, Level: 15 Points: 4,263, Level: 15 Points: 4,263, Level: 15
Thanks: Gave 10, Got 0
I'm using a Somfy ERIT728840, AC Motor IR Receiver. It comes with remote which you can use or learn into a pronto for example. Will interface with any 4 wire screen. I think it retails at £130 roughly, but again, this was a CI by my installer, have a search on the web.
Old 18-02-2004, 9:10 AM   #4
6,103, Level: 18
Cheers for the info. Looks like nexix are doing them for £130.
Kentlad
Old 18-02-2004, 11:23 AM   #5
ReTrO's Avatar
15,958, Level: 30
Kentlad
£130.00 + VAT (£152.75)
Old 20-02-2004, 2:00 PM   #6
petrolhead's Avatar
16,379, Level: 30
Points: 16,379, Level: 30 Points: 16,379, Level: 30 Points: 16,379, Level: 30
Thanks: Gave 97, Got 54
You could use a VT1 video trigger from here Then buy an 80MV relay
Old 20-02-2004, 6:02 PM   #7
4,575, Level: 16
Points: 4,575, Level: 16 Points: 4,575, Level: 16 Points: 4,575, Level: 16
Thanks: Gave 2, Got 14
Why not just add a +12v feed out of your amp to a £1 relay?
That will cost you next to nothing for the complete solution....
