Center channel with dynaudio’s.
Old 29-01-2004, 1:24 AM   #1
steveTHX
Posts: n/a
Well its not finished yet so I cant say how it sounds, but with dynaudio speakers it can only sound great.. more details soon.
pic 1:
http://briefcase.pathfinder.gr/downl...10442/0/C1.JPG
pic 2:
http://briefcase.pathfinder.gr/downl...10443/0/C2.JPG
pic 3:
http://briefcase.pathfinder.gr/downl...10444/0/C3.JPG
pic 4:
http://briefcase.pathfinder.gr/downl...10445/0/C4.JPG
pic 5:
http://briefcase.pathfinder.gr/downl...10446/0/C5.JPG
pic 6:
http://briefcase.pathfinder.gr/downl...10447/0/C6.JPG
pic 7:
http://briefcase.pathfinder.gr/downl...10449/0/C7.JPG
pic 8:
http://briefcase.pathfinder.gr/downl...10450/0/C8.JPG
pic 9:
http://briefcase.pathfinder.gr/downl...10451/0/C9.JPG
pic 10:
http://briefcase.pathfinder.gr/downl...0452/0/C10.JPG
pic 11:
http://briefcase.pathfinder.gr/downl...0453/0/C11.JPG
pic 12:
http://briefcase.pathfinder.gr/downl...0454/0/C12.JPG
pic 13:
http://briefcase.pathfinder.gr/downl...0457/0/C13.JPG
pic 14:
http://briefcase.pathfinder.gr/downl...0458/0/C14.JPG
pic 15:
http://briefcase.pathfinder.gr/downl...0459/0/C15.JPG
pic 16:
http://briefcase.pathfinder.gr/downl...0460/0/C16.JPG
pic 17:
http://briefcase.pathfinder.gr/downl...0461/0/C17.JPG
pic 18:
http://briefcase.pathfinder.gr/downl...0462/0/C18.JPG
pic 19:
http://briefcase.pathfinder.gr/downl...0455/0/C19.JPG
pic 20:
http://briefcase.pathfinder.gr/downl...0456/0/C20.JPG
Old 29-01-2004, 6:14 PM   #2
Conspicuous Member
Gary Lightfoot's Avatar
27,965, Level: 40
Points: 27,965, Level: 40 Points: 27,965, Level: 40 Points: 27,965, Level: 40
Activity: 19.6%
Activity: 19.6% Activity: 19.6% Activity: 19.6%
Thanks: Gave 42, Got 520
Great post.
I do like to see step by step builds like that, as it leaves almost nothing to guesswork as to how something was done. Very useful for others who perhaps weren't brave enough to try it until they'd seen something as detailed as this.
Looking forward to the finished product and your review.
Gary.
Old 29-01-2004, 7:03 PM   #3
steveTHX
Posts: n/a
thanks alot mate..
Old 31-01-2004, 12:20 AM   #4
7,622, Level: 20
Points: 7,622, Level: 20 Points: 7,622, Level: 20 Points: 7,622, Level: 20
Thanks: Gave 20, Got 35
That looks great. It'll probably sound better than my Audience 42C.
I thought Dynaudio don't sell drivers to DIYers anymore.
Old 31-01-2004, 12:26 AM   #5
steveTHX
Posts: n/a
they dont, at a store here there are only a few pieces left and i'm going to try and get them all....
Old 03-02-2004, 11:03 AM   #6
Paul Smith's Avatar
4,561, Level: 16
Points: 4,561, Level: 16 Points: 4,561, Level: 16 Points: 4,561, Level: 16
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 24, Got 51
It's all looking very interesting,
Any chance of some more details to whet our appetites:
Which model drivers are they?
What size is the enclosure?
What frequency is it vented to?
What sort of crossover are you planning for?
Cheers,
Paul.
p.s It's similar to something I am doing at the moment (although I am using Morel drivers).
Old 04-02-2004, 10:21 PM   #7
steveTHX
Posts: n/a
Thanks guys for your comments. Well the woofers are dynaudios 17w75XL with 3inch voice coil, and the tweeters are SEAS 25TFF..now, the enclosures size is H55x D35x W25, the hole speaker isn’t finished yet cos I haven’t found any time to finish the out side, so I cant tell you how it sounds, but I believe the dynaudios wont let me down. The Xover is been designed by a friend of mine which is a specialist with xovers and he will be using some crossover plans from dynaudio.. i’ll be back soon with new pictures…cheers
