Hello everyone!
im new and not very good with all this so please excuse me!
Basically, i have just bought a new lcd tv 42" its 20.5kg in weight.
The big problem we have is putting it on the living room wall, at the mo its on a stand and obviously would much rather it was on the living room wall but the wall we want it on is a plasterboard wall with the bedroom on the other side of it.
We bought a stud finder and found that we had metal studs that were spaced at a distance at all four corners of the bracket that we're using, so really only four corners of the bracket leaves us only four screwing points? Is there a way around this or does anybody know what kind of bolts to use and will only four corners be good enough for a 42" lcd?
The bracket has lots of holes to put lots of bolts thru it but because of the lack of metal studs behind the wall i wasnt too sure if it was still possible or secure enough to just use the four metal studs that the stud finder found?
im so sorry if this all a bit vague!!!!
im rubbish at all this forum stuff so please forgive the vagueness!! and please anyones help would be really grateful!!
Thanks people xx
Ps i dont think there is any timber at all in the wall?? i think its just metal studs? would this still be possible to do????
