Help with this idea
Old 20-11-2009, 10:55 AM   #1
1,957, Level: 10
Points: 1,957, Level: 10 Points: 1,957, Level: 10 Points: 1,957, Level: 10
Thanks: Gave 1, Got 0
Help with this idea
Hi guy's i need some help with electric's i can do it, just need your input on how i can tidy it all up, and see if there is a need for the 2g socket behind the stereo and dvd player, i would just like the one FCU and the brush plate's.
Thank's for any help, and i'm new to the forum.
[IMG]file:///C:/DOCUME%7E1/MUM%7E1.PAI/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
Old 21-11-2009, 8:44 AM   #2
2,914, Level: 12
Points: 2,914, Level: 12 Points: 2,914, Level: 12 Points: 2,914, Level: 12
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 6, Got 30
Hi, my personal opinion would be when possible try to retain a ring, and to do this I would, replace the twin you have with 2 singles so you can split the ring and then extend the ring from these to the new locations and re-join the ring at that point. For the TV I would just fit a standard switched socket and use the plug top that comes with the TV for fuse protection, don't see the point of having a switched fuse outlet. Hope this helps, also if you wanted power in the loft you could add a socket in there as well.
Old 21-11-2009, 9:57 PM   #3
1,056, Level: 7
Points: 1,056, Level: 7 Points: 1,056, Level: 7 Points: 1,056, Level: 7
I tend to agree with Askpakers you have basically got to retain the ring main what you are doing is taking a spur of the socket and with new regs you can only have one socket or fused connection unit on that spur.
Hope this helps.
