Originally Posted by Docta teef As long as your not making any structural changes eg knocking out a wall you shouldn't need to go through building regs though if you did decide to dig down and have it underpinned then i assume you would. Personally when i had my cellar done i went for a membrane with a sump and pump there are pics on the link at the bottom but it doesn't have any pics of the building work as i lost them  |
If you don't go through a building regs app and undertake a conversion, from basic storage to habitable space, omitting things like insulation, or worse, like not creating a means of escape in the event of fire, then come to sell the property, you may be asked for a completion certificate from your local authority.
If you don't have one, the best case is that the space is designed to comply anyway and you can get retrospective approval, worst case is that it does not comply meaning you either have to go through the hassle and extra cost of bringing it up to specification, or reduce the price accordingly.
Worst worst case, you've got no means of escape, you sell the property and someone uses the space as a kids bedroom/playroom, there is a fire at ground floor level and the stairs cannot be used for escape..
So, you either want to do this properly or you do not. My advice is not to believe what you read on the internet, believe what your local authority building control officer advises you
