TV Mounting! Help
Old 13-11-2009, 11:11 AM   #1
2,024, Level: 10
Points: 2,024, Level: 10 Points: 2,024, Level: 10 Points: 2,024, Level: 10
TV Mounting! Help
Hi guys,
Just moved in to a new flat which is timber framed. I haven't had a decent enought chance to check, but I think its just stud framework between me and the flat next door.
I want to do a floating wall but would like the TV mounted to the real wall so it is more flush with the floating wall (like Groove's floating wall)
What can I do to fix the TV to the wall. It will be the same as Grooves in that the mount will be fixed on to the timber work of the floating wall, which in turn should be mounted to the battens of the main wall.
My idea is to build my framework in relation to the real stud work behing the plaster, then fix up with horizontal battens and screw the mount directly into these, rather than fixing to the real wall.
Does this sound feasible?
It's a 42" Panny G10
Old 14-11-2009, 5:11 PM   #2
2,024, Level: 10
Re: TV Mounting! Help
Serioulsy, no one?
Old 16-11-2009, 1:14 PM   #3
3,718, Level: 14
Points: 3,718, Level: 14 Points: 3,718, Level: 14 Points: 3,718, Level: 14
Thanks: Gave 21, Got 55
Yes. It sounds like the ideal solution.
