Anybody thought about making their own audio cables?
Old 10-11-2009, 11:55 AM   #1
dazzler9000's Avatar
4,537, Level: 15
Points: 4,537, Level: 15 Points: 4,537, Level: 15 Points: 4,537, Level: 15
Thanks: Gave 57, Got 31
I was looking some of my RCA and digital leads and thought why don't I make my own.
My Digital Coaxial cable is made from Belden 1694a and is terminated with Canare plugs. I know you'd have to buy crimps etc but has anybody gone down this route?
Old 10-11-2009, 1:20 PM   #2
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
Re: Anybody thought about making their own audio cables?
I`ve been making my own cables for 40 years
infact I make the best sub cables I`ve ever seen (IMHO)
Old 10-11-2009, 2:32 PM   #3
4,537, Level: 15
Hi Al,
Love the build by the way!!
Can you elaborate? What cables have you used and any pics and other details would be nice....
Old 10-11-2009, 8:38 PM   #4
24,693, Level: 38
Sub cables
I use very high quality low noise instrument cable, its double shielded rubber cable, very flexible.
RCA`s are gold plated, insulated with cable support.
Speaker cables are 100% oxygen free copper 184 strand which even over very long runs are excellent.
there should be loads of pics on my 2 threads but if not I`ll take some if you want
thanks for the build comments btw
Old 10-11-2009, 10:00 PM   #5
4,537, Level: 15
Hi Al,
Cheers for the info. I had a quick look on your thread but couldn't see any (those are long threads). Would you mind taking some photos?
Don't get me wrong, I can get a very nice quality Mark Grant 5 metre sub cable for £30, but I kind of like the idea of buying the bits and making them myself. Am I mad?
Old 11-11-2009, 10:01 AM   #6
gareth_alien's Avatar
1,360, Level: 8
Points: 1,360, Level: 8 Points: 1,360, Level: 8 Points: 1,360, Level: 8
Thanks: Gave 11, Got 19
Probably.
But what's that got to do with cables?
Old 11-11-2009, 10:25 AM   #7
4,537, Level: 15
Good question??
Old 11-11-2009, 9:03 PM   #8
4,537, Level: 15
Anybody else??
Old 11-11-2009, 9:36 PM   #9
8,116, Level: 21
Points: 8,116, Level: 21 Points: 8,116, Level: 21 Points: 8,116, Level: 21
Thanks: Gave 25, Got 91
Ive been considering this before aswell and have made a few cables for various things! I think to make the most of the Canare connectors you need their crimp tool which I seem to remember is very expensive! I think to do them it would cost too much for my liking despite the satisfaction factor!
Old 12-11-2009, 8:55 AM   #10
4,537, Level: 15
Yes, I've read it's fairly expensive.....
It's a shame really, as it would great to make your own cables, as you need them and to the correct lengths.
It would also be nice to know that you're not getting ripped off by the big brand names.
Old 14-11-2009, 12:24 PM   #11
2,487, Level: 11
Points: 2,487, Level: 11 Points: 2,487, Level: 11 Points: 2,487, Level: 11
Thanks: Gave 16, Got 23
If you can use a soldering iron, there are many companies out there that sell quality connectors ,fairly cheaply.........
I'm just about to start mocking up my system, I'll set it all up with trailing wires to check everything works before commiting to plaster and conduit in the walls, some of the cables are 'homemade', it pays to test eveything, plus some of my HDMI runs are >7m, so it'll be a good idea to check they're ok with 1080p before I can't get them out again!
Give the DIY cable a go.
Remember, heat the work, not the solder
Old 15-11-2009, 11:35 AM   #12
4,537, Level: 15
Cheers chaps, I think I'll give it ago when I get some time.
I may check out the Canare route, as I've heard that they're a very good connector....... and they certainly look the part
Anybody made their own HDMI?
Old 15-11-2009, 12:19 PM   #13
7,185, Level: 20
Points: 7,185, Level: 20 Points: 7,185, Level: 20 Points: 7,185, Level: 20
Thanks: Gave 280, Got 96
think there is a big thread about using cat5 cables for speakers too
Old 15-11-2009, 1:20 PM   #14
4,366, Level: 15
Points: 4,366, Level: 15 Points: 4,366, Level: 15 Points: 4,366, Level: 15
Thanks: Gave 24, Got 54
i dont think hdmi connectors are available yet
Old 15-11-2009, 2:24 PM   #15
8,116, Level: 21
I think you can get them from some places, but of course there will be no benefit in making HDMI leads! Seeing as a cheap HDMI lead will do the same as an expensive one of course...!
Old 15-11-2009, 9:45 PM   #16
4,537, Level: 15
Good point, decent HDMI's are reasonably priced anyway. (£5-15)
I was having a read about cat 5 speaker cables the other day. Interesting to say the least.... especially as I work in networking!!
