I'm using rope lights in my Living room, around my projector screen and in my hallway.
The ropelights are wired differently in both locations.
The photo below shows how its connected up in the living room. The light is dropped behind the plasterboard through a hole and wired (not plugged) into a 5 amp fused spur behind the white cabinets (more photos in
my thread).
In place of the spur was a 5 amp lamp socket which was luckily already wired into the main light switch for the room. All I did was replace the lamp socket with the spur and I permanantly leave the spur switched on. I controlled the on/off and brightness of the ropelight via the switch on the wall. The wall switch also happens to be a varilight remote dimmer switch available from TLC and B&Q so that I can programme any IR remote control to operate the light from the sofa.
In the hallway its slightly different. Im using a 10m run of ropelight from one end to the other and have that hooked up via motion sensor. There are 4 ways to enter into the long hallway so Ive positioned a
wireless motion sensor to activate when motion is detected.
The ropelight is plugged into a
wireless standby socket which is then plugged into the mains. When motion is detected the wireless motion sensor sends a signal to the standby socket which activates and turnes on the ropelights (or whatever you want to connect to it).
There are various settings on these devices which allow you to control the length of time the connected device stays on for and at what level of lightness the motion sensor should operate under. Ive set mine to stay on for approximately 1 min and to only activate when it is dark (no point it turning on during the day). Ill post a couple of pics of the sensors in action tomorrow.
What were you planning on using the ropelights for? You could get
this kit which has the standby socket and a wall mountable switch that you can put anywhere in the room (or another room).
