Recommendations for wall mounting AV equipment
Old 02-11-2009, 10:56 AM   #1
3,657, Level: 14
Points: 3,657, Level: 14 Points: 3,657, Level: 14 Points: 3,657, Level: 14
Thanks: Gave 5, Got 8
Hi all
I'm about to take out my fireplace (no chimney breast) and get my LCD and AV equipment wall mounted.
I'm trying to find the best solution for this. Bracket for TV is no problem but i'm struggling to find the right solution for the other equipment.
I'm after something similar to this but possibly with glass shelving instead of brackets:
EFA 8840
The only problem I am having is that my AV amp is 14Kg and most of these systems state that each shelf supports only a weight of 10Kg.
Anyone come across any solutions out there that might be suitable? I'm after mounting the AV amp, a blu-ray player, sky box and XBox.
Old 02-11-2009, 1:00 PM   #2
gareth_alien's Avatar
1,360, Level: 8
Points: 1,360, Level: 8 Points: 1,360, Level: 8 Points: 1,360, Level: 8
Thanks: Gave 11, Got 19
Re: Recommendations for wall mounting AV equipment
Personally I think that Vogels mount is a bit big and intrusive. That said, I don't know of anything else; unless you can have a custom job made.
- Gareth
