Floating wall - why smooth?
Old 23-10-2009, 3:04 PM   #1
1,400, Level: 8
Points: 1,400, Level: 8 Points: 1,400, Level: 8 Points: 1,400, Level: 8
Greetings everyone. I'm confused about why everyone is smooth sanding their floating walls.
I'm in the US and have lived in over 15 different places. None of them that I can remember have had smooth walls, they're all skip trowel texture. Some people call this orange peel so you get the idea.
Anyway, I would like to use drywall with the standard skip trowel finish for my floating wall. It will be painted Chocolate Brown; the surrounding walls are a lighter shade of brown.
Is a skip trowel finish OK to use in my setup? Why or why not?
Thanks much.
Old 23-10-2009, 4:58 PM   #2
4,366, Level: 15
Points: 4,366, Level: 15 Points: 4,366, Level: 15 Points: 4,366, Level: 15
Thanks: Gave 24, Got 54
Re: Floating wall - why smooth?
is it called skip towelled because thats where the trowel should be - in the skip
not heard this before, over here we go for smooth finish or a defined texture not orange peel effect as this just looks like a bad paint job
i would however use the 3D mdf with the routed texture
Old 23-10-2009, 5:45 PM   #3
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
Classic answer Dean
but your right mate, over here in blighty all the artexskip/trowel or whatever textured finish is slowly disappearing and we`re all going flat smooth.
So much cleaner finish imho.
Also the darker you go the more the image will stand out
but if you prefer a textured finish then go for it, whatever floats your boat
Old 23-10-2009, 7:06 PM   #4
7,008, Level: 19
Points: 7,008, Level: 19 Points: 7,008, Level: 19 Points: 7,008, Level: 19
Thanks: Gave 78, Got 50
I couldnt be bothered with all that sanding & so I used a dark, thick, textured wallpaper on mine. Just an idea?
Old 23-10-2009, 7:30 PM   #5
4,366, Level: 15
like i said if you go for texture go for a bigger 1 not orange peel
Old 24-10-2009, 2:31 PM   #6
1,017, Level: 7
Points: 1,017, Level: 7 Points: 1,017, Level: 7 Points: 1,017, Level: 7
Thanks: Gave 8, Got 9
Couldn't agree more, currently suffering with woodchip here but landlord doing a major internal refurb next year and giving us smooth walls - when that is done here comes a floating wall!
