12V Trigger Wire Query
Old 22-10-2009, 11:03 AM   #1
big john 1983's Avatar
4,140, Level: 15
Points: 4,140, Level: 15 Points: 4,140, Level: 15 Points: 4,140, Level: 15
Thanks: Gave 197, Got 34
Just running all the cables in my living room at the moment and wondered what wire to use for the 12V trigger wire from PJ to screen?
Could I use some 1mm cable? (Overkill...I know, but I've got loads and should be more protected than other stuff)
John
Old 22-10-2009, 3:44 PM   #2
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
Re: 12V Trigger Wire Query
1 mm will be fine, how long is the run btw
Old 23-10-2009, 5:04 AM   #3
4,140, Level: 15
Many thanks for the reply.
The run is only about 4m.
John
