The moving picture link has given me an option. Although I can't use a picture due to a feature wall I have, similar to the rectangular blocks "The Force" has in his in his living room, I do still want to
1. cut a projector hole through to the next room
2. use automation.
I want the use one of the rectangular blocks as a flip up doorway like this
Does anyone know if linear actuators can be used to open and close this (if so how) and also how easy/hard is it to link up to the 12v trigger of the pj?
Not a great google mock up, but if you see the top row of blocks being three across rather then the two shown, it would be the middle one that I would create the hatch through.
It will be approx 12" x 26" x 1" made of MDF and obviously hinged at the top to a framework created inside the partition wall.
On the back side of the wall (the projector side) I may go for a sliding picture or similar.
