Earthing Home Cinema Kit
Old 16-10-2009, 8:55 AM   #1
4,391, Level: 15
Points: 4,391, Level: 15 Points: 4,391, Level: 15 Points: 4,391, Level: 15
Thanks: Gave 47, Got 70
Any electricians in the house?
While reconnecting my Home cinema set-up recently I noticed that ALL of the components have two pin mains connectors - none have a connected earth wire. Do I need to find a way to create at least one Earth in the system - I know not to create an earth loop.
Old 18-10-2009, 2:07 PM   #2
Illustrious Member
Sonic67's Avatar
16,893, Level: 31
Points: 16,893, Level: 31 Points: 16,893, Level: 31 Points: 16,893, Level: 31
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 1,346, Got 1,774
Re: Earthing Home Cinema Kit
If equipment has a double hollow square on it then it doesn't need an earth.
Old 18-10-2009, 3:14 PM   #3
4,391, Level: 15
That means it is double insulated. I thought some electronics needed a good earth to stop noise - rather than for the "Earth as a fault protection" system.
Old 18-10-2009, 4:39 PM   #4
Illustrious Member
Sonic67's Avatar
16,893, Level: 31
Activity: 1.9%
If so there should be a connection for it. Usually a binding post with a thumbscrew.
Old 03-12-2009, 11:02 PM   #5
3,958, Level: 14
Points: 3,958, Level: 14 Points: 3,958, Level: 14 Points: 3,958, Level: 14
Thanks: Gave 1, Got 1
Hi, Just read your post and thought i'd reply.
If your equipment is all double insulated it not only does not need a earth (or cpc (circuit protective conductor) as we now must call it!) but it would be dangerous to attach one!!
Ian.
