room 'panels'
Old 29-12-2003, 5:59 PM   #1
Sly Sly is offline
Sly's Avatar
6,990, Level: 19
Points: 6,990, Level: 19 Points: 6,990, Level: 19 Points: 6,990, Level: 19
Thanks: Gave 46, Got 21
room 'panels'
having read this months HCC mag i have noticed in the featured home cinema they have used panels on the walls to cut down on sound reflections and offer a (small?) amount of noise dampening.
have any of you guys tried this?
Old 29-12-2003, 6:11 PM   #2
fufna
Posts: n/a
Am currently building a load for my cinema.... i built in pretty serious cavity stud walls all round to cut out low frequency resonance , but this does not really help to control errant high frequency refections so after some testing I decided to panel the walls at intervals.
The panels are of different thickness and are all intercahngable.
Old 29-12-2003, 7:18 PM   #3
Sly Sly is offline
Sly's Avatar
6,990, Level: 19
what sizes compared to what sized walls?have you done any tests?what materials are you using?
sorry to be a pest!
Old 29-12-2003, 10:43 PM   #4
4,725, Level: 16
Points: 4,725, Level: 16 Points: 4,725, Level: 16 Points: 4,725, Level: 16
Thanks: Gave 9, Got 34
Sly,
Have a look at this thread, Rockwool rigid slabs - suitable for acoustic treatments? It might give you a few ideas.
Old 30-12-2003, 1:11 AM   #5
fufna
Posts: n/a
sorry to be a pest!
My walls are:
10ft (screen and rear wall)
14ft (side walls)
at the moment the panels are 2ft x 6ft
They are of wooden frame construction filled with studio grade 2" thick very dense acoustic foam.
the frame is then to be covered with cloth (when i can choose it!)
HTH
Old 30-12-2003, 8:06 PM   #6
Sly Sly is offline
Sly's Avatar
6,990, Level: 19
can you post pics/results/tips/etc as you go , as i would be intrested to see how it goes.
ta.
p.s. thx for the link pemberto!
