Pe for the DVC 15 is 600w.
Full spec here:
http://www.partsexpress.com/pdf/295-190s.pdf
A ported cabinet with an f3 of 19hz is around 275l (about 9.75 ft^3), remember I said the bigger the speaker the bigger the cabinet.
You could use 2 driver's in an isobaric (face-to-face) configuration like SVS does for the B4, that will halve the size of cabinet you need at the expense of losing efficiency because you're now using 2 motor's to drive the same effective cone area, so you'll need a more powerful amp. Btw, if you're going for ported you want the amp without equalisation (or ask PE how to disable the boost on the boosted amp) because your simulation software assumes a flat frequency response for the supplied power.
Alternatively you could go for the MKIII Titanic driver:
http://www.partsexpress.com/pe/pshow...295-420&ctab=1
This brings your cabinet down to around 200l (about 7 ft^3) for the same response and it can handle 800w instead of 600w. Cheaper than 2 DVC drivers, doesn't shift as much air as 2 DVC but more than 2DVC in an isobaric config.
At that price you're in AV15 territory:
http://www.stryke.com/AVseries.html
which is only another $10. Stryke do not normally carry them as stock, they build a batch and when they're sold you could have a long wait for the next batch to be built. Parts Express are a bigger operation and will ship when you order and you'll get them in 2-3 weeks.
Personally, I'd say stop mucking about and get one of these:
http://www.adireaudio.com/diy_audio/...ire/tumult.htm
If I ever get the pair I ordered in November,
I'll let you know how they sound!
EDIT:
Btw, WinISD Pro (alpha) is the better of the two versions, if you have Excel then use Unibox it's much easier to understand.
http://www.danbbs.dk/~ko/ubmodel.htm
