A Quick Sketchup Plea
Old 22-08-2009, 11:54 AM   #1
Tyler Durden's Avatar
6,306, Level: 18
Points: 6,306, Level: 18 Points: 6,306, Level: 18 Points: 6,306, Level: 18
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 134, Got 66
I cannot get my head around sketchup, would someone be so kind as to put together a quick layout for me?
Here are the dimensions for my false chimney breast idea,
Current flat Wall - 3.6m x 2.4m
False Chimney Breast = 220cm x 240cm x 20cm (to be centred on current wall)
TV - 1233mm x 723mm (to be recessed into the centre of the chimney breast at mid height with 50mm gap all round)
Centre - (HxWxD) 760 x 120 x 105mm (to be recessed into the chimney breast below the TV with 10mm gap all round)
Fronts - (HxWxD) 925 x 120 x 140mm (to be recessed into the chimney breast either side of the TV with 10mm gap all round)
The current wall will remain a cream colour and the chimney breast will either be painted a dark chocolate colour or wallpapered in something like this Wallpaper Direct - Oralia
Many Thanks in advance,
TD
Old 22-08-2009, 7:17 PM   #2
2,868, Level: 12
Points: 2,868, Level: 12 Points: 2,868, Level: 12 Points: 2,868, Level: 12
Thanks: Gave 2, Got 1
Re: A Quick Sketchup Plea
Gave it a shot, its a bit rough and i didn't bother adding depths of speakers/ tv in im afraid. They could be addded relatively easily i suppose, I just didn't do it!
I'm pretty new to sketchup too, so it is very beginner work!
Tyler Durden (23-08-2009)
