Channeling in cables for new Plasma - Help!
Old 20-08-2009, 3:01 PM   #1
3,988, Level: 14
Points: 3,988, Level: 14 Points: 3,988, Level: 14 Points: 3,988, Level: 14
Thanks: Gave 42, Got 3
Hi all
Finally have my TV bracket on the wall after much research and help from AV forums on wall anchors that are strong enough to hold a Panasonic 50" G10 on a plasterboard wall - thanks all!
My next challenge is to channel in the HDMI/aerial/Power cables into the wall. As this is my first attempt I'm more than a little nervous at the thought of cutting sections out of a wall that was build less than 9 months ago!
Reading around the Forums here it seems I need to channel into the wall (around 1 metre from top to bottom), insert plastic conduit which is secured to the wall by screws/rawl plugs, then plaster over it.
As this is my first attempt I need some advise from you experience people.
- What do I use to cut the plasterboard?
- What type of conduit should I use?
- Any hints on covering over the conduit/replastering? What should I use?
- And any problems with having a power cable and the HDMI, etc cables in the same conduit?
Thanks!
Old 20-08-2009, 3:31 PM   #2
Conspicuous Member
21,528, Level: 35
Points: 21,528, Level: 35 Points: 21,528, Level: 35 Points: 21,528, Level: 35
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 4, Got 1,393
Re: Channeling in cables for new Plasma - Help!
You could always do this solution D-Line Plasma Tv Trunking PVC Dline at least if you have a problem or need to add/subtract cables you do not end up snookered.
Old 20-08-2009, 3:43 PM   #3
3,988, Level: 14
Thanks - I had considered that, but really I want to hide the cables in the wall for an all round better look.
