choice of tv aerial and speaker cables
Old 20-08-2009, 10:44 AM   #1
1,956, Level: 10
Points: 1,956, Level: 10 Points: 1,956, Level: 10 Points: 1,956, Level: 10
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 32, Got 33
hi looking to get a high gain uhf tv aerial, seen a philex 48 element one for £20 but then seen aerials costing twice as much and more! is this one ok is there a difference in how much you spend? i live in a good signal area so no problems there, just dont want to spend when dont need to.
on another note was told to get QED original speaker cable but quite expensive, seen some IXOS XHS 223 cable which is half the price and it says that it is aimed at the QED original buyer, anyone with experience of the IXOS?
any comments gretly appreciated
Old 10-09-2009, 3:53 AM   #2
MarkP80's Avatar
6,231, Level: 18
Points: 6,231, Level: 18 Points: 6,231, Level: 18 Points: 6,231, Level: 18
Thanks: Gave 112, Got 99
Re: choice of tv aerial and speaker cables
Hi there,
I use VanDamme blue speaker cable, relatively cheap and good quality.
Regards,
MarkP
