VGA Connector / Faceplate / plug socket type thing
Old 17-08-2009, 2:57 PM   #1
berkeley384's Avatar
4,602, Level: 16
Points: 4,602, Level: 16 Points: 4,602, Level: 16 Points: 4,602, Level: 16
Thanks: Gave 68, Got 78
I want to put a kind of VGA connector on the side of my fake chimney breast, so that a cable can run internally within the chimney through to the TV and terminate on the side wall. That way when I want to hook up the lap top I can just plug it in to the connector on the side of chimney and use the LCD screen as my monitor.
Any ideas?
Old 17-08-2009, 5:01 PM   #2
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
Re: VGA Connector / Faceplate / plug socket type thing
check these out Steve
Your Search Results | CPC
very simple to do mate, shout if you need hand, also think about audio as well if you need it
Al
berkeley384 (18-08-2009)
Old 18-08-2009, 6:46 PM   #3
4,602, Level: 16
Al
Al your a superstar, thats exactly what I was after !
albriscoe (19-08-2009)
