I am just about to start extending our bungalow to add a new section that includes a cinema upstairs - see pics with sizes. New section is in yellow. Just got planning approved this week.
I need to decide if I will build the first floor in 150mm concrete hollowcore with a 75mm screed on top (separated by 25mm insulation so the top screed is floating), or use 300mm I-beams with a floating floor on top. I'm not sure if normal joists will cover the spans so they might not be an option.
Any advice on how I should progress? Having the cinema room isolated as much as possible is VERY important. Would I need a floating floor on top of the concrete floating screed? Room height will become an issue... I know I'll need to put in a second stud wall with double plasterboard all around, and may use green glue. Other than green glue I'd prefer to stick with standard building materials as in Rep of Ireland so carriage would be an issue, not to mention our prices for anything non standard.
Have I enough space to allow 2 rows of seats? Should I lengthen or widen the room? I based the room dimensions on an "ideal cinema room dimension ratio" I found on the net but the drawings show that I should be able to widen a bit to the left (although will be left with a sloping ceiling at the top of the left wall) and move the chimney breast back a foot or two to lengthen the room.
Note I need minimum 300mm insulation in the roof and possibly will lose even another 75mm inside whats shown if I slab with insulation-backed plasterboard.
Thanks for any advice, I dont want to regret later what I can change now!
Steve
