exstension ,how much?
Old 28-11-2003, 6:15 PM   #1
shoalin kid's Avatar
8,584, Level: 22
Points: 8,584, Level: 22 Points: 8,584, Level: 22 Points: 8,584, Level: 22
Thanks: Gave 3, Got 18
anyone know how much an exstension measuring roughly 6m x 4m would cost it might be built separetlly from the house on a hard standing area next to the house ,but ive no idea how much this would be .it would solve my problem with next door
Old 29-11-2003, 10:44 AM   #2
Supra's Avatar
4,386, Level: 15
Points: 4,386, Level: 15 Points: 4,386, Level: 15 Points: 4,386, Level: 15
Thanks: Gave 29, Got 13
try getting a couple of quoyes from vartious builders, some can give you a rough estimate usually x£ per sq metre. will you need planning permission?
if you most of the work yourself you can save a fortune, I added a 7m x 3 metre extension to my house, the materials came to roughly,4k, i stoppped keeping records after a while. Done alot of the work myself. I only got one quote from a builder it was 15k. Id rather save the money and spend it elswhere, actually the mrs spent the saving on a 9k kitchen!
whatever qoutes you get make sure you have 20% backup funds.
By the way i decided on apitched ceiling, this had to confirm to new building regs, had to use an insulation material called celotex. I was quoted £800 for this by builder dentre. After a morning on the tel i managed to aquire it for £375!. Abuilder will charge you top dollar for materials. Its amazing how much you can save if you look around. All the above was of brick construction.
I thin Jewsons do some pre fabricated buildings which can work out cheaper, depends how much you want to spend really.
The downside to doing it youself id it takes ages, I stared in march and only now am nearing the end.
hope that helps.
Old 29-11-2003, 12:18 PM   #3
8,584, Level: 22
thanks mate i ll have to do some research ,my girlfriends brother knows a builder who has done some work for us in the past .i dint think the materials would be that much ,never mind.by the way wats a pitched ceiling
