Originally Posted by AdzAV I also think they have been installed for a purpose and are not satisfying that purpose as they are not secure. |
Also agree with this. I couldn't quite figure out if the rafters are attached to the joists where they meet the wall plate. If so, I guess there shouldn't be a problem. However, if not then the weight of the roof timbers, tiles etc will mean the roof naturally wants to push the walls out, and I suspect this is what the vertical timbers are supposed to be preventing, although I would have expected more than two if so!
My bet would be that taking these timbers out would not make any difference if they are wobbling around so much. A good idea would be to fit some ridge collars on each pair of rafters to help stop the spread. Looking at the size of the loft though I guess the rafters are pretty long, so collars alone might not be enough.
Anyway, to cut a long story short, find a friendly builder/roofer and ask their advice. It will all be possible for relatively small £££s.
Cheers.
