Originally Posted by RipMaster What size screen do you want and do you know which model of projector you are going to get? Looking at that setup and using a quick mockup I did in sketch up then the biggest issue you are going to have with that room is probably the projector placement and throw ratio limiting the screen options. |
Ripmaster, thank you so much for such a thorough response. Wow! I am really impressed with your drawings and renders !!! Are you an architect or interior designer ?
You are 100% right, one of my biggest concerns has been projector placement because of the limiting throw ratio.
If you have the funds if I were you I would seriously consider putting in some sort of attic window/dormer type recess that would give you more roof space at the short end of the room. I think that would give you a lot more options regards screen size, projectors and placement.
That sounds like a good idea and I have been pondering over the issue. I will definitely have a word with a builder to find out if we can incorporate such a recess. I agree, it would solve the problem in terms of projector placement & screen size.
Because the seating area is quite close to the screen, I am thinking of installing an 80 inch wide (16:9) screen (92"Diagonal). I am very keen on the InFocus IN83 DLP projector but according to the projection calculator, for an 80" wide sceen, the short throw distance is 3.84 meters. For a shorter throw distance, I've been looking at alternatives such as the JVC DLA-HD350 and the Marantz VP-15S1 which I believe have shorter / better throw ratios (by about 1 meter if I'm not mistaken)
That is to scale showing a 1.8m wide sofa placed about 2 feet from the wall. Screen is 8 feet wide 16:9. With a setup like that you could probably avoid having the projector directly above you or above and to the front which would make the room a lot more comfortable a place I would have thought.
Will be needing seating for at least 5 to 6 people, small but comfortable seats would be the answer i think.
Yes, it would be good to avoid the projector being directly above due to the louder fan noise in DLP projectors and to make the room more comfortable.
Any idea how the recess could be incorporated considering the fact that there are wooden beams going from front to back ?
