29 oz sealant/caulk gun
Old 16-07-2009, 12:32 PM   #1
Stoatman's Avatar
11,970, Level: 26
Points: 11,970, Level: 26 Points: 11,970, Level: 26 Points: 11,970, Level: 26
Thanks: Gave 20, Got 89
This may be a silly question but I have searched high and low online and cannot find one. DOes anyone know where you can get a 29oz /1 quart sized caulking gun from, there is a green glue product which requires one but I just cant find them.
thanks
Chris
Old 16-07-2009, 1:21 PM   #2
4,031, Level: 14
Points: 4,031, Level: 14 Points: 4,031, Level: 14 Points: 4,031, Level: 14
Thanks: Gave 0, Got 6
Re: 29 oz sealant/caulk gun
Is it a US size? Can you get the gun from a US supplier?
Old 16-07-2009, 1:57 PM   #3
Stoatman's Avatar
11,970, Level: 26
Yes a US size, but there are a few products out there in this 29oz size tube I thought they would be readily available but it looks like im wrong.
Old 16-07-2009, 2:26 PM   #4
4,031, Level: 14
Would this work?
Dryzone product pictures - Dryzone
The gun takes foil cartridges?
Ben
Old 16-07-2009, 2:36 PM   #5
4,366, Level: 15
Points: 4,366, Level: 15 Points: 4,366, Level: 15 Points: 4,366, Level: 15
Thanks: Gave 24, Got 54
i that is the 1 litre guns then you can get them from drylinig places like cpd, ccf, encon or sheffield insulation
Old 16-07-2009, 3:21 PM   #6
4,366, Level: 15
www.toolbank.com | Jumbo Sealant Gun 900ml Cartridges | Home Hardware Southwest Limited
Old 16-07-2009, 5:27 PM   #7
Stoatman's Avatar
11,970, Level: 26
Thanks alot man thats great !. Hmm bit pricey though , why does that green glue stuff have to come in a big one .!?
Old 16-07-2009, 5:32 PM   #8
4,366, Level: 15
if you buy acoustic sealant it comes in a 900ml tube. also i hve notied that stone audio sell a gun for £25
Old 16-07-2009, 6:35 PM   #9
amioa's Avatar
2,256, Level: 11
Points: 2,256, Level: 11 Points: 2,256, Level: 11 Points: 2,256, Level: 11
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 9, Got 100
£15 from the people who sell it, and there was a link on here a few days ago for one for less than £10
Old 16-07-2009, 6:42 PM   #10
barney007's Avatar
2,400, Level: 11
Points: 2,400, Level: 11 Points: 2,400, Level: 11 Points: 2,400, Level: 11
Thanks: Gave 940, Got 503
Hi matey,
dont know if i may be able to help you, but are you after acoustic sealent? or just the gun?
i work in the fireprotection industry and i have to use acoustic sealent day in day out lol...
Old 16-07-2009, 8:18 PM   #11
Pulsar's Avatar
8,032, Level: 21
Points: 8,032, Level: 21 Points: 8,032, Level: 21 Points: 8,032, Level: 21
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 60, Got 22
thanks
Chris
Chris,
Where are you located? I may be able to lend you one if you're local.
Rob
Old 17-07-2009, 8:44 AM   #12
Stoatman's Avatar
11,970, Level: 26
Hello mate,
Well that is a very kind offer , im in middlewich cw10 . A little background on the project. I have found a supplier of the silenseal stuff, to seal some floorboards and around the perimeter of an upstairs room to try and help with noise. I was surprised to find that its only about 7 pounds a tube. I thought it would be more judging by the price of the proper green glue adhesive. Uk link here :
Green Glue Slide Show
Old 18-07-2009, 3:43 PM   #13
Pulsar's Avatar
8,032, Level: 21
Activity: 1.0%
Hello mate,
That is a good price. Do you know how it performs when compared to GG?
I don't think it worth posting the cartridge gun, would probably cost more than buying one.
I'd be very interested to hear how you get on with the silenseal as I need a bit more GG and don't want to fork out for another 12 tubes and £15 per tube is just ridiculous IMO.
Rob
Old 18-07-2009, 5:09 PM   #14
Stoatman's Avatar
11,970, Level: 26
No worries mate, ill get one from somewhere. Regards the glue itself I think the silenseal is more of a perimeter acoustic grade sealant as apposed to the actual green glue is used as an adhesive isn't it ??, to stick plaster board up with . Im not sure that the silenseal would do that but it might be worth asking them. Although at half the price they are probably unlikely to recommend it over green glue !. THanks again.
Old 20-07-2009, 8:40 PM   #15
Pulsar's Avatar
8,032, Level: 21
Activity: 1.0%
Green glue isn't actually a glue (misleading name I know). When it dries (that takes AGES) it has the consistency of fresh snot / bogeys. It is still quite elastic and can be deformed with little pressure and it is this consistency that makes it good at absorbing vibrations/sound (I believe).
Anyway, good luck with your project.
Rob
Old 21-07-2009, 8:19 PM   #16
amioa's Avatar
2,256, Level: 11
Activity: 1.4%
Rob
£15? who is that from?
Old 21-07-2009, 8:34 PM   #17
Pulsar's Avatar
8,032, Level: 21
Activity: 1.0%
Stone audio. STONEAUDIO UK | hi-fi, home cinema, multi-room, design and installation
Rob
