Hiding wires from PLasma screen?
Old 19-11-2003, 1:14 PM   #1
robyoung's Avatar
6,000, Level: 18
Points: 6,000, Level: 18 Points: 6,000, Level: 18 Points: 6,000, Level: 18
Thanks: Gave 35, Got 62
Hi guys,
looking for any tips on hiding wires from my wall mounted plasma screen, they look awful just hanging. Its mounted on a brick wall, so any siggestions/pics? what have you done or seen done?
thanks rob
Old 19-11-2003, 1:21 PM   #2
8,490, Level: 22
Points: 8,490, Level: 22 Points: 8,490, Level: 22 Points: 8,490, Level: 22
Thanks: Gave 18, Got 30
Have a look at the 'Get your plasma out for lads thread' for some inspiration: http://www.avforums.com/frame.html?h...threadid=78824
Prior to burying the cables for mine in the wall, I got 2 lengths of plastic pipe, sprayed to match the frame of the plasma, fed the cables through the pipes and attached them to the wall using blutak - you can see how it looked on page 7 of this thread: http://www.avforums.com/frame.html?h...threadid=91523
HTH
John
Old 19-11-2003, 3:17 PM   #3
robyoung's Avatar
6,000, Level: 18
Thanks, yours looks really neat! might try that as a quick cheap fix, although not sure whether to paint it wall colour or the aluminium colour of the telly.
Any tips/instructions on doing it through the wall? can it be done DIY? They only need to go straight down.
Many thanks
Rob
Old 19-11-2003, 4:46 PM   #4
8,490, Level: 22
The wife wanted to paint the trunking the same colour as the walls but I figures by painting it silver, it gave the impression that the TV was on a stand.
I put the cables in the wall myself - got some rectangular trunking from B&Q and cut a channel in the plasterboard with a stanley knife - attached the trunking to the breeze blocks behind using No More Nails.
The front of the trunking was slightly behind the front of the plasterboard so a thin coat of polyfiller a bit of sanding and some paint and the wall looks good as new.
I'll try to get some pics and post them later.
John
Old 19-11-2003, 4:59 PM   #5
robyoung's Avatar
6,000, Level: 18
Thanks John,
Pics would be cool. Might attempt to do the wall if its possible with the brick. I'll have a look in B&Q too for the trunking (is it specifically for wires?)
thanks rob
Old 19-11-2003, 8:40 PM   #6
taimur's Avatar
9,551, Level: 23
Points: 9,551, Level: 23 Points: 9,551, Level: 23 Points: 9,551, Level: 23
Thanks: Gave 5, Got 0
trunking is in the electricity section of a B&Q. If you have plaster walls, then you can cut a channel down the wall with an angle grinder, insert the trunking, and plaster over the trunking. I have gyproc walls so it was a little easier for me but someone I know bought himself an angle grinder to hide all his multiroom speaker wires.
Old 20-11-2003, 6:27 AM   #7
Taz
Posts: n/a
Originally posted by taimur
[B] you can cut a channel down the wall with an angle grinder,
or a wall chaser, a handy tool to have..
http://www.screwfix.com/app/sfd/cat/...11900&ts=09575
Old 20-11-2003, 10:23 PM   #8
taimur's Avatar
9,551, Level: 23
how does a wall chaser work?
Old 21-11-2003, 6:20 AM   #9
Taz
Posts: n/a
Its rather like a router but for walls, you stick a drill in that caddy insert the supplied bit adjust the depth and wheel your drill up the wall cutting a slot as it go's
Old 21-11-2003, 8:52 PM   #10
taimur's Avatar
9,551, Level: 23
I want one! but I'll have to move house into one with plaster walls first!
Old 22-11-2003, 12:02 AM   #11
Dominic's Avatar
5,132, Level: 16
Points: 5,132, Level: 16 Points: 5,132, Level: 16 Points: 5,132, Level: 16
Thanks: Gave 0, Got 6
anyone used an angle grinder to channel walls out ? jesus what a load of dust,
i installed my kitchen this summer and put loads of cables in, sky/cat5/coax/LV lighing/ uplighters. i started using an angle grinder, but the amount of dust was toooo much,
so i got my SDS drill with a chisel on the end and hammered myself some nice channels. deep enough for trunking.
Old 27-11-2003, 2:52 AM   #12
3,861, Level: 14
Points: 3,861, Level: 14 Points: 3,861, Level: 14 Points: 3,861, Level: 14
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 4, Got 3
Hire a proper wall chaser and INDUSTRIAL VACUUM from a tool hire shop there will be next to no dust at all
Old 28-11-2003, 1:59 PM   #13
9,943, Level: 23
Points: 9,943, Level: 23 Points: 9,943, Level: 23 Points: 9,943, Level: 23
Thanks: Gave 0, Got 5
wher can you buy those rubber cable conselers for the floor that you find in offices.
Old 28-11-2003, 3:39 PM   #14
8,490, Level: 22
rob,
I've just posted pics of my setup in the Get you Plasmas out.... thread.
John
Old 14-12-2003, 5:03 PM   #15
6,152, Level: 18
Points: 6,152, Level: 18 Points: 6,152, Level: 18 Points: 6,152, Level: 18
Anyone know where i can get my hands on a couple of component BNC type wall sockets.
Want to run the cable through the wall and terminate them at both ends within normal wall sockets that i can then plug the component cables into, to make it a neater job and easier to move at a later date.
Old 14-12-2003, 7:48 PM   #16
3,861, Level: 14
Activity: 0.7%
Try screwfix a 9m roll is £66.45
Old 14-12-2003, 7:52 PM   #17
3,861, Level: 14
Activity: 0.7%
try:-
www.keene.co.uk
look under the "home installation and diy leads" section they do all manor of wall plates and can make up others to order.
