For my school project I am going to make a loudspeaker system. It is going to contain a tweeter, Mid range and woofer. The parts I intend to use are showsn below:
Tweeter: Standard Horn > Maplin Mid Range: 51/4” 60W Shielded Bass/Mid Woofer > Maplin Woofer: 1x 902.420 5.25" 200W Hi Fi Kevlar Cone Woofer Speaker on eBay (end time 05-Jul-09 22:22:23 BST)
I think I need a 3 way crossover so this is the one I thought of using:
Three-Way 12dB/Octave 150W > Maplin
To connect the speakers to the amp I was thinking of using these terminals:
Twin Terminal Post > Maplin
along with these:
Banana Plugs with Gold-Plated Contacts > Maplin
I am going to make a box myself which will house the speakers (made from MDF).
I am not expecting this to sound amazing, it is only my first project and just want to know if this will work. If I need any other components then please tell me.
Could anyone tell me what kind of wires I would need? and how to connect the speakers together (series maybe?)
It would be great if you could help me along with this
Thanks.
