managed to get some more done:
filled and painted around the cable for the screen and got the first ceiling mounted bass trap in. Wickes RW 30mm thick in timber frame with 20mm air gap behind. Suprisingly heavy !
These will run along the whole central ceiling area and do hit the first reflection points from the front speakers.
They measure a metre wide and will run the full 5.7metres along the ceiling so should be pretty effective.
May also continue with the panels onto the front wall above the screen, triangular bass mounts it's the future !:
trial fitting for the large superthick rug to see if i can get first reflections on the floor: it seems to be about right for the right speaker but the sette is in the way for the left side - no idea what that means ????
The centre speaker first reflection will be covered by the rug.
The coffee table will be an issue if i decide to plonk it on the rug:
projector mounted in the ceiling - Optoma HD65 on an extendable mount as i'm still working on the best height for the screen. It is too high at the moment so some serious adjustment / trials needs to be done. The other holes are for an extract fan mounted in the ceiling void so there is no additional noise, linked to the solar panel; and the sockets for switching off the vent and the optoma.
HDMI linked to a booster and composites plugged in at this end - after seperating power and signal leads for the 5metre run they end up going through the same hole !!! :
floating shelves took an age to fit - used three sizes of auger bit and about 8 hours to drill out holes on the rear of the shelves. They then simply slot over the pre-fitted brackets and are very sturdy, may use a lighter timber than oak next time. Tempted to bond / resin them in place for additinoal stability as they could be pulled forward - not ideal when you stick the av gear on top and see my twins looking longingly at the lovely flashing lights.....
tempted to pull the shelves out a bit as they look even more-floaty-like. Also thinking of continuing the shelves up the wall in decreasing sizes to provide some deflection.
view from the front looking back, very pleased with it all so far and still haven't got to the really good bit of installing all the av....
